Failed to start external route update transaction with RTMgr. If this is an add or update transaction then routes will not be updated correctly. If this is a delete transaction then invalid routes might remain in FIB.
Look at logs for any error message from RTMgr. Try to disable export and enable it again.
Error
Failed to start external route %p1% transaction, origin code=%p2%, client ID %p3% %p4% %p5% %p6%
| Name | Type |
| p1 | String |
| p2 | sInt |
| p3 | xInt32 |
| p4 | uInt32 |
| p5 | uInt16 |
| p6 | uInt8 |
